Receiving Some Blank Emails
MortResnick
Thu Mar 15, 2018 6:38 am
Running MWP 7.11.0, Windows 10 and Outlook 2016. I have started to receive emails in MWP where the From and Subject boxes are blank. All other boxes for the same email are completedthis is happening on only one mailbox account. :cry
Re: Receiving Some Blank Emails
Fri Mar 16, 2018 2:35 pm
Under Settings >> General >> Checking Mail >> try bringing the Spam Throttle out to about 500 lines >> Save >> restart MailWasher.
MortResnick
Sat Mar 17, 2018 12:26 am
That fixed it. Thank you so much! I have another problem but I'll start a new thread for it. Many thanks again.
edgar_tim
Thu Mar 12, 2020 2:42 pm
I have same issue but that fix didn't work. Can anyone suggest something else to try to make text in the From and Subject boxes visible? This is not happening on all incoming email, but occurs several times daily. Running MWP 7.12.25, Windows 10 and Outlook 2016
Thu Mar 12, 2020 3:24 pm
You definitely restarted MailWasher after changing ?
Check under Settings >> Accounts >> Incoming >> that Store Cached Email is not checked >> if it is uncheck >> Save.
If the account is IMAP and the option is checked >> set to POP at the top >> uncheck the option >> set back to IMAP >> Save.
