I have created a non default account.
on most occasions when I open MW and click on the "Check Mail" button to check only the default accounts it also downloads the non default account. If I clear the message list and recheck it works fine. I am not using the Check all facility, just the default accounts check.
Anyone else getting this problem and knows how to cure it. Is it a known bug?
Alan
Non default accounts
Re: Non default accounts
On the startup check sounds odd.
If there any messages for the non-default account showing in the list, from a manual check, that would trigger a regular Check Mail to also include the non-default account. MW behaves this way so that a Check Mail keeps all accounts with messages loaded in the list to be current.
Next time you notice the issue, if you can send me some logs, via Help >> Send Support Logs >> enter a brief like '<accountname> should not have checked' >> enter chris as the Ticket Number >> Send Logs.
It sounds like you can cause this issue to happen on demand, so if you can cause issue, send the logs, will make it nice and clear.
- alanrwood
Hi rusticdog
Fantastic quick reply as always. I will do as you request next time it happens. I have just cleared the logs to keep it short.
This happens with no messages shown initially in the list when it happens so I don't think that is not the reason but I was not aware of that behaviour before so will be aware now.
I can't do it on demand unfortunately but it does happen reasonably regularly so it should not be long.
Regards Alan
Regards Alan
Regards Alan
- alanrwood
Hi
The Gremlins have been at work. Since my last post it has only happened once. It might be of course that there were no emails in the non-default account so it would not show. I will keep monitoring it and get back if necessary.
Regards Alan
Regards Alan
Regards Alan
- alanrwood
OK I will close this now as it seems to have sorted itself out. I changed the relevant account to Active. Closed MW then reopened it and set it to inactive again and it seems to have worked. I will get back if I experience it again.
Cheers Alan
Cheers Alan
Regards Alan
