Had a minor crash and i had to reinstall Mailwasher Pro . Kind of forgot how to set it up. Using the latest version 7.11.5. First: Is it possible to get rid of the message "Drag a column header here to group by that column"? And secondly, i can't seem to remember how to change the highlighted colors on the received emails. Thirdly, when Mailwasher was open on the desktop, did it always display on the task bar? I have it configured to close down to the tray when X-ed, and it does, but it appears on the taskbar when it's open on the desktop. Did it always do this? Fourth, the watch tutorial continues showing on startup even though I unchecked the show at startup box.
thanks for your assistance.
Reinstall and a couple of things are bugbears, I need some help
- bardos
- bardos
Re: Reinstall and a couple of things are bugbears, I need some help
With regards to 3, do you want to start MailWasher minimised to the Tray ? Assuming so, under Settings >> General >> Application >> there is an option there to have MW start minimised to either Tray or Task Bar
- JRodShop
I see that you said you solved 1, 2, and 4, 1 being "Drag a column header here to group by that column". I do not, however, see your solutions. I am trying to make that "Drag a column header here" bar go away, and having no success finding the magic button.bardos wrote:Solved 1, 2 and 4...
