From/Subject not showing
genegold
Guardian Gecko
Sat Jun 16, 2018 4:04 am
MW Pro 7.11.0, Win 10. For the past three weeks, an email coming from a list-serve has stopped showing the From and Subject fields in MWP. The Email Header window shows the subject, and in my email client, Sylpheed, everything shows. Where should I be looking for the source of the problem? Screenshots attached - top window, email header window, in Sylpheed (text-based, POP3).
email in Sylpheed
Mailwasher Pro From-Subject problem - 1.JPG (21.95 KiB) Viewed 8582 times
MWP email header window
Mailwasher Pro From-Subject problem email header - 2.JPG (34.98 KiB) Viewed 8582 times
MWP top window
Mailwasher Pro From-Subject problem in Sylpheed.JPG (12.28 KiB) Viewed 8582 times
Re: From/Subject not showing
Sat Jun 16, 2018 12:45 pm
Under Settings>> General >> Checking Mail >> lift the spam throttle to around 500 lines, should be enough hopefully.
genegold
Guardian Gecko
Sat Jun 16, 2018 4:38 pm
Thanks. Mine was at 400. In terms of follow up on this adjustment, I'll be away and won't be able to see these emails again until August.
Sat Jun 16, 2018 4:40 pm
Actually, just saw you were on 7.11.0, download latest beta version, that has a fix for same issue you describe so might not be related to spam throttle
http://cdn.firetrust.com/downloads/mail ... 122017.exe
genegold
Guardian Gecko
Sat Jun 16, 2018 4:46 pm
Yes, I see that mentioned, not that I look (haven't followed the beta forum for some time). Will see the result in a couple of months.
genegold
Guardian Gecko
Mon Jul 23, 2018 7:44 pm
Just back. Still not showing From and Subject in MWP
Mailwasher Pro From-Subject problem email header - 3.JPG (22.96 KiB) Viewed 8467 times
Mon Jul 23, 2018 8:14 pm
OK, can you copy/paste the full source of one of these emails into a text file and send that to me at [email protected]
I've recently come across this happening to another person, the header is so long that MailWasher is aborting the attempt to find the From and Subject, so if that's the same it's a fairly simple fix.
Mon Jul 23, 2018 8:34 pm
Got it thanks. Will add to list for programmers to check out. Does look to be the same long headers, that's almost 300 lines :)
In interim, you could create a custom filter to flag these emails specific to this group, at least then they'd stick out more if you wanted them to.
genegold
Guardian Gecko
Wed Jun 17, 2020 4:21 pm
I see in the new changelog, "Fix for long headers not displaying Subject/From in message list." Finally! There probably won't be a test of it until the end of the week, but hopefully it's really solved. Thanks,
Wed Jun 17, 2020 5:48 pm
I still have at least one example where we might need to extend it further. But yes, fingers crossed it's all good for your situation.
genegold
Guardian Gecko
Sun Jun 21, 2020 8:00 am
Not solved. The listings in MWP still show blank for subject and sender
