Very Slow Start Up
frattonstation
Very Slow Start Up
Thu Aug 16, 2018 3:05 am
Help!
Been using Mailwasher Pro for a couple of years now with no problem.
But for the past two days it has just been hanging on the Startup Splash screen for about 20 mins before opening up, if at all!
I am on Win 10 and have had no problems at all before.
Has anyone got a solution please?
Re: Very Slow Start Up
Thu Aug 16, 2018 9:44 pm
I would first download and run the .NET Repair Utility first and see if that helps https://www.microsoft.com/en-nz/downloa ... x?id=30135
frattonstation
Fri Aug 17, 2018 12:32 am
Will do. Thanks.
Fri Aug 17, 2018 12:33 am
If that fails to resolve the issue, I would next look at a System File Scan, details here
https://support.microsoft.com/en-nz/hel ... ted-system
frattonstation
Fri Aug 17, 2018 2:43 am
.Net Repair fixed the issue.
Very Many Thanks
what would have caused this in the first place?
Fri Aug 17, 2018 4:28 am
There were some recent Windows Updates and perhaps that's what threw .NET into a bit of a fizz. It's not common to have updates cause a problem like that, but about the only thing I can think of.
Glad it's all good now.
