some emails awaiting down load are blank?
MargM
Mon Aug 27, 2018 6:36 pm
Had a few problems in recent times Main reason for using Mailwasher long ago was deleting SPAM emails Been a long time since any SPAM emails rocked up. Unsure whether its outlook Express Classis that's the root cause of some mail waiting to be down loaded is blank... OK once downloaded See file attachment
When I am home I tend to leave my computer on. Quite often mail just down loads its self For an un needed mail like from Facebook would much rather delete off the server . Un sure how to do this ?
Many thanks
MargM
Malwasher problem.PNG (81.35 KiB) Viewed 477 times
Re: some emails awaiting down load are blank?
Mon Aug 27, 2018 6:51 pm
Hi MargM
First check under Settings >> General >> Checking Mail >> have your Spam Throttle set to roughly 500 lines. If it is lower, change that then restart MailWasher and see if that resolves the problem.
If not, then try removing the account from MailWasher >> restart the program >> add the account back in.
