Mailwasher not Deleting Email
mechler
Tue Sep 11, 2018 9:01 am
Why would my Mailwasher (most current version) stop deleting mail marked for deletion? What should I look for?
Thank you
Re: Mailwasher not Deleting Email
Sun Sep 16, 2018 5:36 pm
Sorry for the delay.
So the emails are marked for delete, but not deleting when you Wash Mail ? Are you trying to delete a lot of messages at once ?
Try first doing another Check Mail, to make sure those messages are still present.
There is a setting under Settings >> Accounts >> Incoming >> Advanced >> down the bottom to use PIPELINING when Deleting Mail, that you can uncheck and see if that helps.
