Quick reply or forward using Windows Mail
KnutR
Thu Oct 25, 2018 9:07 pm
I use Mozilla Thunderbird as my e-mail program. This is registered in my Mailwasher. However, when using Quick reply or forward, Mailwasher opens Windows Mail. How can I tell Mailwasher to use the right program? "Start mailprogram" opens Thunderbird, but not Reply or Forward.
Re: Quick reply or forward using Windows Mail
Thu Oct 25, 2018 10:21 pm
If you go into your Control Panel >> Default Programs >> select "Associate a file type or protocol with a program" >> scroll down and select "Choose default apps by protocol" >> scroll down, on the left your are looking for the MAILTO >> once you have that you can click the app on the right and alter back to ThunderBird.
KnutR
Thu Oct 25, 2018 11:29 pm
Thank you - I never thought of that., but now it works fine.
