Small Problem with MWP and Thunderbird 60
RoyReed
Tue Dec 11, 2018 12:12 am
Thunderbird just upgraded to v60.3.3 and now, if I open it via MWP (v7.11.5) it has small error on the header bar (top right). If Tbird opens normally this error isn't there. I'm on Win7Pro 64bit.
Roy
Re: Small Problem with MWP and Thunderbird 60
Tue Dec 11, 2018 12:22 am
There was a discussion about this a couple of years back too
viewtopic.php?f=50&t=18712
Although we never got to the bottom of it.
I assume you have ThunderBird selected under Settings >> General >> Washing Mail. Does this graphic issue improve if you instead select to Use Other Application and select "C:\Program Files (x86)\Mozilla Thunderbird\thunderbird.exe" manually (or copy paste that path including the quotes).
RoyReed
Tue Dec 11, 2018 12:59 am
Yes, that cures the problem. It's no big deal, but it is a strange little issue.
Roy
