Need help recovering from a crash
linkup
Postby linkup Thu Dec 13, 2018 2:00 pm
Hello, I am running MWPro on a Win7Pro machine. I had a SSD as a boot drive which crashed.
I tried to figure this out on my own as I did it once before. I followed the instructions about installing MW. Then I copied my backed up AppData/Roaming/Firetrust/Mailwasher files from the backup to the new install.
Then I open MW and it acts like brand new. Asks me to set up my first email account and none of my info is there.
I am sure I am doing something stupid or missed something in the instructions?
Could I have been running an older version and it isn't compatible? I know the GUI looks different than the version I was running.
I can't find where to download V6?
Help please.
Re: Need help recovering from a crash
Postby rusticdog Thu Dec 13, 2018 2:10 pm
You can download the old MW 6 from here http://cdn.firetrust.com/downloads/mail ... -Setup.exe
Unfortunately this version also stores the settings and accounts in the Registry, your AppData/Roaming/Firetrust/Mailwasher files you copied only includes Friends List, Blacklist, Learning and the Recycle Bin. The settings and accounts will need to be set again.
Postby rusticdog Thu Dec 13, 2018 2:15 pm
Also to add, if you install v6, copy the files into ....\AppData\Roaming\MailWasherPro
The install process will create this folder, just wanted to note it's a slightly different path than the v7 folder.
linkup
Postby linkup Thu Dec 13, 2018 2:30 pm
OK....after tyring to copy over again, I found what you just said about email setting not copying over. You didn't mention filters either. I care more about filters than I do anything else.
Postby rusticdog Thu Dec 13, 2018 2:54 pm
MailWasher 6 stores the filters as filters.txt within ....\AppData\Roaming\MailWasherPro
So long as you copy that file across it should work. Be sure MailWasher is not running when copying the files across.
MailWasher 7 uses a different format for filters, so those cannot be copied from 6 to 7.
Who is online
Users browsing this forum: No registered users and 20 guests
