2 email accounts problem
Hjalle
Wed Dec 19, 2018 2:54 am
Hi
I am experiencing the following problem.
When i launch MWP 7 free, the programs shows mails for both my POP 3 accounts.
However, when i wash the mails, only 1 account receives the mail, and it is always the same account that receives.
I am using Windows Live Mail.
What am i doing wrong?
Re: 2 email accounts problem
Sat Dec 22, 2018 12:27 pm
Hi there
Sorry for delay
Both accounts are setup in Live Mail ? If so, and you don't use MailWasher can you ever receive the mails for the 2nd account into Live Mail ?
Hjalle
Sun Dec 23, 2018 2:26 am
Hi Rusticdog
Both accounts are setup in Live Mail, without Mailwasher it delivers all mails to both accounts and we - the wife and i - sort it out from there.
Sadly my ISP doesn't support IMAP :-(
Hjalle
Thu Jan 03, 2019 6:29 am
bump
Thu Jan 03, 2019 12:03 pm
OK. After the deletes in MailWasher, in WLM what happens when you hit Send/Receive, do the messages for the other account then come in ?
If not, click the down arrow beside Send/Receive and click the option to Receive All, do they come in then ?
Hjalle
Sat Jan 05, 2019 11:00 pm
No.
The mails still only appear in the inbox that is primary in MailWasher.
Neither hitting send/receive nor hitting Receive All makes any difference.
Sun Jan 06, 2019 11:26 am
It sounds like Windows Live Mail might not be setup correctly for the 2nd account. It should be able to retrieve the mail manually, unless it had an incorrect password or other setting.
Here's a link on how to find those settings in WLM https://support.siteapex.com/email-c30. ... splayOrder
Check what you have entered against your email providers recommendation
Hjalle
Wed Jan 30, 2019 6:46 am
rusticdog wrote:It sounds like Windows Live Mail might not be setup correctly for the 2nd account. It should be able to retrieve the mail manually, unless it had an incorrect password or other setting.
Both accounts are setup correctly...
Wed Jan 30, 2019 12:44 pm
MailWasher cannot prevent WLM from retrieving emails on a particular account. When was the last time WLM was able to bring the emails down for the problem account ? Is it possible the password entered in WLM is incorrect ?
