Amount of KB sent to spamcop.net
cvalde
Postby cvalde Mon Dec 24, 2018 6:50 pm
Hello, I've found differences between spam that I forward to Spamcop via MWP and spam that I copy/paste into Spamcop's web submit form. I narrowed it to one cause: MWP seems to be forwarding too few KBs, maybe 2 KB to Spamcop but when I use their submit form, more information can be sent. The result is that spamcop is able to analyze more hyperlinks in the message body. Because html has gotten more complex and voluminous, in some cases, forwarding via MWP doesn't let spamcop pick even the first hyperlink. Was the MWP limit on forwarding set on a indication by Spamcop or was an educated guess? How can I configure the amount of KB forwarded to do some tests?
Thanks.
Claudio.
Re: Amount of KB sent to spamcop.net
Postby rusticdog Mon Dec 24, 2018 7:01 pm
Hi Claudio
There's unfortunately no way to change the settings that MailWasher uses for SpamCop, but you are right, the amount we set MailWasher to use was done a number of years ago and emails have gotten larger since then. I'll add to the list to either configure SpamCop or introduce a higher limit.
Thanks for bringing this to our attention!
Chris
cvalde
Postby cvalde Tue Dec 25, 2018 7:10 am
Thanks to you for your quick reply.
Claudio.
Who is online
Users browsing this forum: Majestic-12 [Bot] and 19 guests
