During the past few days my Mailwasferpro is not starting and I get this error message
https://cdn1.imggmi.com/uploads/2019/1/ ... 7-full.png
FYI I am using Windows 10 and it worked just fine until a few days ago. I have not installed any new hardware or software since then.
Does anyone have a clue what may be causing it and what is the best way to fix the problem?
Mailwasher Pro does not start
Re: Mailwasher Pro does not start
Try uninstalling then reinstalling MailWasher first if you have not done so already, opt to keep your data files when prompted.
I would then try running a .NET Repair https://www.microsoft.com/en-nz/downloa ... x?id=30135
If that still fails, try running a System File Scan
https://support.microsoft.com/en-nz/hel ... le-checker
