Whenever I try to update I'm presented with the Modify/Repair/Uninstall screen. If I choose Modify or Repair some quick actions are taken but I'm still left with my current version of 7.11. Is there any way to get the update applied without having to uninstall?
Thanks!
Jerry
Unable to update to 7.12.1
Re: Unable to update to 7.12.1
Hi Jerry
No, uninstall would be best here. It will prompt you about keeping your data files, so be sure to keep those and you won't lose any settings when you reinstall.
