Mailwasher status
- jcoates23
Mailwasher status
MailWasher keeps marking Good and Friend e-mails as spam. For example, I just registered for this forum and received an email from Mailwasher to activate my account. Mailwasher marked the email as spam. How can I stop this?
Re: Mailwasher status
It sounds like MailWasher has a lot of spam mails that have been trained as Spam, and not enough Good.
First go into Settings >> Spam Tools >> Spam Ratings >> set the Friends List all the way to 200 >> Save.
Then under Settings >> General >> Checking Mail >> be sure the Spam Throttle is set to at least 350 lines
When MailWasher gets messages wrong, you are correcting the email using the Thumbs Up/Down button ?
- jcoates23
Thanks for the quick reply.
Spam rating was already at 200.
Spam throttle was way below 350. I reset to 350.
I always correct using the buttons and also reset to Friend.
Hopefully the throttle reset will help.
OK great, give it a couple of days, but with more email data to work with, that will mean MailWasher can be more accurate
