Copy Bug IMAP settings ver 7.12.1
razorflash
Fri Mar 15, 2019 9:47 am
In the field for e-mail address in general page for imap settings, the email address is not copied the second time if changed to incoming and outgoing settings for the email address. If you write an email address with errors and correct it, the errors will prevail in the rest of the settings though you changed it at the first general page. I think this is a bug. If the e-mail address is changed in the general page then should this new address propagate the rest of the settings. HawkEye
Re: Copy Bug IMAP settings ver 7.12.1
Fri Mar 15, 2019 10:37 am
Hi there
Thanks for the suggestion/report, will add to the list.
Cheers!
