Startup Tips splash screen
- USAOz
Despite UNTICKING "Show At Startup", the Mailwasher splash page offering tips etc. STILL appears EVERY time I open Mailwasher. ANNOYING! How do I stop this from happening?
Re: Startup Tips splash screen
If you right click on the shortcut you use to start MailWasher >> select Properties >> under the Shortcut tab click in the Target field >> arrow across all the way to the right and add a space and -nosplash to the end >> It should then look something like
"C:\Program Files (x86)\Firetrust\MailWasher\MailWasherPro.exe" -nosplash
Click OK.
Click OK.
