I don't use Outlook and I want to get rid of that Icon alongside Wash Mail.
How can I do that?
Freshly installed MWP has Outlook link at the top.
- dmb06851
Re: Freshly installed MWP has Outlook link at the top.
Under Settings >> General >> Washing Mail >> you can choose another email program you have installed in the drop down.
If you just use the webmail, like www.gmail.com then instead select to Use Web Address and enter in the webmail URL
- dmb06851
Thank you. That's done it.
