Lost email.
Arnak
Lost email.
Tue Jun 18, 2019 7:20 am
I have mailwsher pro 7.12.1.
Today I accidentally deleted a vital email which should not be a problem but when I checked in the recycle bin it is not there. :oops:
The other deleted emails from the same time are there but not that one.
Has anyone any idea where it could have gone please?
Thanks.
Martin
Re: Lost email.
Tue Jun 18, 2019 12:06 pm
Hi Martin
In the Recycle Bin, click the option at the top Show All Email Logged, see if you can see it then.
Also it might be wroth disabling the internal cache. Under Settings >> Accounts >> Incoming >> uncheck Store Cached Email >> Save.
If the accounts are set to IMAP, switch them to POP at the top, then uncheck the option, then set back to IMAP >> Save.
