Hello,
I'm new to MailWasher and this app is just what I needed!
One question I have is regarding the profanity list and it's purpose... When activated does it just blur the email text or does it also mark the mail as spam?
Thanks!
Profanity list
Re: Profanity list
Hi there
It's just a blur effect, it won't use those words to determine spam or good.
When you train/classify emails as good and spam, it takes the most interesting words in those emails for learning instead, they may be the same in the end.
- tjerin
Re: Profanity list
Thanks for the quick reply. If that's the case then would it make sense to build a custom filter using all the words in that list? My thought was that with a custom filter it would mark those as spam immediately. Whereas if I rely on training the Bayesian filter it might take a long time to get everything on that list filtered out. Is that a good assumption?
Re: Profanity list
Generally speaking you should start seeing results once around 150 emails have been trained. MailWasher does come pre-trained with some words, but every user is different so it's always better to rely on your own messages.
I would personally let the Learning try first, and consider tweaking with Custom Filters later.
