As I have noted in an earlier post: I had a problem with my hard drive that caused me to have to reinstall MW.
I have blacklisted a number of senders that I don't want to see in my daily emails.
They show up as blacklisted and checked for deletion, as I expected.
But what I really want is for these blacklisted senders to go directly to the recycle bin, with no action from me.
Will it take a filter to accomplish this or is there a switch I've overlooked?
If it will require a filter, could someone please give me the filter settings?
Any help with identifying a fix for this would be greatly appreciated by one old guy.
Thanks!
Blacklist automatic actions
Re: Blacklist automatic actions
Hi again
To specifically delete Blacklisted emails automatically, the easiest way is under Settings >> Spam Tools >> Blacklist >> click the Options tab >> you'll see the auto-delete setting there.
- Gene2018
Hello again, too.
You solved my second problem, too.
Thanks for your help, again!
