Hi Guys,
I have just updated my Avast Premium Security to the latest version, and it has taken exception to MWP.
In that it will not allow MWP to access my mail servers unless I deactivate the Avast "Mail Shield".
Is there something I have missed here?
I did have the same issue (same programs) a couple of years ago - but it seemed to resolve itself - i.e. "Mail Shield" active and MWP performing correctly as it should.
As above upon update it has re-appeared.
Is there a work round?
It is causing a bit of concern, (Not with MWP) because Avast would certify incoming and outgoing mail, (clearly visible when MWP checked mail).
This aspect is now missing, because of the deactivation of "Mail Shield".
Obliged for any and all advice.
PS:
I have send a copy of this message to Avast - but as yet no reply.
MWP and Avast Premium Security
- dustyv
If it can go wrong -
It will
If it cannot go wrong - It will try to
Re: MWP and Avast Premium Security
Sorry no work around from our end, Avast Mail Shield has always been pretty much junk, so I'd just leave it off.
- dustyv
Thank you for your reply - appreciated.
I think I had anticipated your answer as the issue is not with MWP, but with Avast.
I asked if there was a work around, because some other issues have resulted in work around's being made by your 'Brilliant' forum members.
But alas not this one.
I have lodged a report with Avast, no reply as yet, if and when I receive one I will let you know, I am not holding my breath though.
Thanks for your time and advice - well appreciated.
Please consider the issue as closed - Cheers.
It will
