are they updating this anymore?
- Digerati
- Retired Microsoft MVP
Bill (AFE7Ret)
Freedom is NOT Free!
Re: are they updating this anymore?
Yes. As a Firetrust beta tester, I can tell you they frequently push out new beta versions for us to test. So I assure you work is being done. In fact they working on a major upgrade now that will become available once everyone is satisfied it is working properly.
And remember, New Zealand has had some recent significant problems with Mother Nature with volcanoes, fires, and earthquakes. I believe some have affected some of the developers (or their families) directly.
So don't worry. The project is still very active - at least behind the scenes.
