I recently had to change my Yahoo password. I have changed it accordingly in Mailwasher, but can't log in.
The system says "Failed to connect to serve.r"
What can I do to fix this?
Can no longer log in to Mailwasher.
- dmb06851
Re: Can no longer log in to Mailwasher.
Under Settings >> Accounts >> Incoming >> Advanced >> try checking Use OAUTH >> recheck the account and follow the on screen prompts, where you need to logon to the Yahoo account via pop-up, give MailWasher access, then enter the code in the field down the bottom and click OK.
If the Use OAUTH option was already checked, try going Help >> User Files >> Cache >> delete the file named emailaddress_token, where emailaddress is your Yahoo email addy.
