can't install 7.12.25
Gonzague
Sat Mar 28, 2020 12:13 pm
I have Windows 7 home. I can't install Mailwasher pro 7 -7.12.25 from the auto update or from installer downloaded from firetrust.
I get this error " C:\programdata\firetrust\MWinstall7.12.25\setup.msi. Verify that the file exists and that you can access it"
I tried to install it as administrator and with antivirus off but it didn't help.
picture of the error attach
7-12-25 error.jpg (74.49 KiB) Viewed 2808 times
Re: can't install 7.12.25
Sat Mar 28, 2020 12:19 pm
That's odd. Can you uninstall, but keep your data files when prompted, or do you get the same error ?
Gonzague
Sat Mar 28, 2020 12:50 pm
I didn't try to uninstall yet. I try to install many time. if I open the program data folder before I install and start the installer I can see the setup.msi appear,
but when the installer stop and I click cancel. I can see the 7.12.25 setup.msi disappear.
If there is no better way than to uninstall the old one, I will try it tomorrow
Gonzague
Sun Mar 29, 2020 8:45 am
I was able to uninstall and keep the data, but when i tried to install I got the same error again as above. so I decided to clean the
the registry and all the mailwasher and firetrust folders, I did take a copy of the user appdata roaming mailwasher folder.
Then I was able to install MailWasher 7.12.25 and before starting mail washer, I put the appdata roaming mailwasher folder back in
so I still have my settings and accounts like before.
It was not a very smooth update, I must say
Mon Mar 30, 2020 2:14 pm
No, quite odd to be getting that error. Fingers crossed it's all good now for future installs.
