Not working for me. If I click on the HTML view button, MW still crashes.Fix for crash on HTML toggle
HTML crashing v7.12.29
- Elektra
- Active Albatross
Re: HTML crashing v7.12.29
Does it do this on every email, or just specific ones ?
If it's only certain emails, if you view one these emails in Plain Text >> click Show Email Info at the top left >> click the Source tab >> right click over the email text and select Select All >> then right click over the text again and select Copy >> paste that into a text file and send to me at [email protected].
Don't paste the text straight into an email, as the email formatting with alter it.
Also if you can send me some logs. Help >> Send Support Logs >> enter a brief note like 'hmtl crash' >> Send Logs.
- Elektra
- Active Albatross
You didn't give me a ticket number RD so I sent the logs with a subject of HTML crash.
It doesn't appear to crash with all HTML mails but it won't display them properly, even if I activate the remote content option.
I have sent you source code by mail as requested.
