I've recently had to add a second profile to my Outlook 365 desktop client - and now, every time I launch Outlook from Mailwasher, I have to pick the profile I wish to use.
Is there any way in Mailwasher to **specify** what profile to use - once and for all times? I can define it on the command line for my shortcuts on my desktop - but I haven't found any way in Mailwasher to define that.
If that's not in there yet - I'd definitely put a request in to add this as a feature in a future release of MW !
Launch Outlook as mail program - with a specific profile
Re: Launch Outlook as mail program - with a specific profile
In MailWasher under Settings >> General >> Washing Mail >> if you set the email program to Use Other Application >> then using the Browse if you navigate to your desktop and choose the custom Outlook shortcut >> Save.
That should in theory open the right profile.
