1 PC, 2 Users, only 1 gets "View in HTML" button.
TheWeasel
Mon May 18, 2020 2:00 am
Ver 7.12.29
For the one without the button, the first line reads "This email contains dynamic content that is unsupported in Plain Text version. To view it, please refer to the HTML version of this email."
If this email is forwarded to the second user, the button appears and works as expected.
If an email is sent to both users, only the one has the View In HTML option.
Is there a setting that controls this?
Thanks.
Re: 1 PC, 2 Users, only 1 gets "View in HTML" button.
Mon May 18, 2020 3:12 am
We do have a beta that has a recent fix that might correct this. It will install fine over the top.
http://cdn.firetrust.com/downloads/mail ... _12_36.exe
Also under Settings >> General >> Checking Mail >> set the Spam Throttle to 500 lines. It will slow down MailWasher a touch retrieving emails, but will give it more email content to work with and should make this button more reliable.
TheWeasel
Mon May 18, 2020 4:00 am
Thanks. I installed the beta and set throttle to 500 but it didn't help.
So I set the throttle to the max (9999) and now the View In HTML button appears.
The extra lines don't seem to slow things down much, so I'll just leave it maxed.
