Backing Up MW Pro
Andrew42
Backing Up MW Pro
Mon Jun 22, 2020 8:32 pm
Forgive me if this has been dealt with elsewhere. I've looked, but in vain. I have just had to do a clean reinstall of my laptop. Mailwasher Pro is, therefore, a brand new installation. Too late I thought of backing up my history so MW would already have a list of my good and bad sites. I then thought, well too bad, because I do not know what and where to back up so that in future I can preload my history. Thanks for the help. With your reply, please could you tell me if the folders I need to backup can sit inside OneDrive so backing up becomes irrelevant.
Re: Backing Up MW Pro
Mon Jun 22, 2020 8:45 pm
C:\Users\[your username]\AppData\Roaming\Firetrust\MailWasher is the folder you want.
Optionally in MailWasher >> File >> Export >> if you give the file a name and save location, it will store the the above in single .MWP file (which is just a ZIP file) that when run will import all the data back into MailWasher.
Andrew42
Mon Jun 22, 2020 8:54 pm
Perfect. Thanks. I've set it up to Backup to OneDrive and Append.
