unknown error
philsbbs
unknown error
Sat Aug 22, 2020 11:29 pm
Just got :
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>62bfd976f63970a26c0b10e108b8c9ac</ID><DT>2020-08-22 12:23:24</DT><MWPEXCEPTION><UID>Exception 9e8d81aabfefca78d5c2270160305c60</UID><AID>Acct1393492846</AID><SOURCE>MWPfetch::FetchThread()</SOURCE><MESSAGE>Unknown error</MESSAGE><ADDXML></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
Ive sent the log files for review.
Have a good weekend and Stay Safe.
Phil
philsbbs
Re: unknown error
Tue Aug 25, 2020 5:00 am
bump.
Re: unknown error
Wed Aug 26, 2020 4:31 pm
Sorry, got behind on things.
Can you try the .41 version (will install fine over the top) and see if the problem persists.
http://cdn.firetrust.com/downloads/mail ... _12_41.exe
Chris
philsbbs
Re: unknown error
Wed Aug 26, 2020 8:57 pm
Tired install keep getting attached message.
http://www.huntingtreepark.com/delete.jpg
Re: unknown error
Wed Aug 26, 2020 9:05 pm
Odd. Try running the installer for .36 and select Repair when prompted, once done try the .41 install again.
http://cdn.firetrust.com/downloads/mail ... _12_36.exe
Re: unknown error
Wed Aug 26, 2020 9:07 pm
Scratch that, you are on .38 so it won't let you.
Uninstall, keep data files when prompted. Then run .41 version installer.
If that still gives error you posted, then do the .36 install followed by .41
philsbbs
Re: unknown error
Wed Aug 26, 2020 10:17 pm
another error trying uninstall http://www.huntingtreepark.com/delete2.jpg
Re: unknown error
Wed Aug 26, 2020 10:18 pm
OK, try the install of .36. You should be prompted to Repair the install that will hopefully sort all this out.
philsbbs
Re: unknown error
Wed Aug 26, 2020 11:30 pm
start migration ?
Re: unknown error
Wed Aug 26, 2020 11:35 pm
start migration ?
Yup, that should be fine, means the database structure is altered slightly so some data needs to be reworked.
philsbbs
Re: unknown error
Wed Aug 26, 2020 11:41 pm
migration has done and its loading the mail, next step ?
Re: unknown error
Wed Aug 26, 2020 11:45 pm
On .36 ? Then try installing .41 over the top now.
philsbbs
Re: unknown error
Thu Aug 27, 2020 12:01 am
.36 will try upgrade now
philsbbs
Re: unknown error
Thu Aug 27, 2020 12:04 am
.41 install now asked for start migration ok I take it ... ?
Re: unknown error
Yup
