I have three email addresses logged into Mailwasher. One of them is listed as "Dominant", but it is no longer the email address I prefer to use, and eventually it will be phased out, although not yet.
I would like to make one of the other email addresses the Dominant one in Mailwasher. How can I switch it to Dominant, and make the present Dominant address a secondary one?
Thanks,
RMS1
Alter Dominant email address
- RMS1
Re: Alter Dominant email address
I have solved my own problem. In Mailwasher, click on Settings - Accounts, and alter the Account Description for each email address, then save the settings.
- Digerati
- Retired Microsoft MVP
Bill (AFE7Ret)
Freedom is NOT Free!
Not really sure what you mean by Dominant but if you mean at the top of the list, if you look at Settings > Accounts and loot at bottom of the Accounts list, you will see "Check order:" with arrow up and arrow down buttons. You can highlight an account then use those buttons to sort them in the order you want.
