I have an odd situation: selecting an email from the list shows the detail from a completely different email in the preview pane.
So an incoming email from a Covid information site shows an advert from a wine merchant in the preview.
This makes it difficult to decide how to categorise and deal with it!
Selected email header shows wrong preview
Re: Selected email header shows wrong preview
Check under Settings >> Accounts >> Incoming >> that Store Cached Emails is not checked. If it is, uncheck >> Save >> restart MailWasher.
If the account is set to IMAP and that setting is checked, set the account to POP >> uncheck the option >> set back to IMAP >> Save >> restart MailWasher.
Also try disabling Fast Startup and if laptop Hybrid Sleep.
https://www.pugetsystems.com/labs/suppo ... ation-793/
Ignore the first steps about disabling regular Sleep and Hibernation, those should be kept. Is just disabling Windows holding extra in memory when entering those states.
