Now Gmail server is returning error
genegold
Guardian Gecko
Thu Oct 08, 2020 6:21 pm
In September I posted about Yahoo problems with MWP. When I finally figured out that the latter needed to use IMAP with Yahoo, Gmail was working fine. I had set the server check to 2 days and could see the message at the bottom of the screen as it did it. Sometime since then it started failing, which I just realized yesterday, but can't figure out why, since nothing I can find has changed. It's for an organization account and both the boss and my emails have had notices for a couple of outsider login attempts recently, but other than that everything looks right in MWP and Gmail's settings, including less secure apps allowed and Gmail forwarding allowed. Not sure where to go with figuring out the problem. Any ideas? Thanks.
Re: Now Gmail server is returning error
Thu Oct 08, 2020 6:35 pm
When you say it's an organisation account, do you mean it's just a regular GMail account used by a business, or is it a GSuite account ?
If it's GSuite, then GMail has likely disabled access to programs that do not use OAUTH and you would need an App Password to use in MailWasher.
If it's a regular GMail account, does it work in your email program ? and if so, do you know if that program is using OAUTH to access the account.
Interestingly, Digerati has the opposite, his GMail stopped working for reasons unknown and just started working today
viewtopic.php?f=50&t=32411
genegold
Guardian Gecko
Thu Oct 08, 2020 6:46 pm
It's the community opera organization and I don't know if they use GSuite and will have to check, tho I never heard of it. But did the difference (disable) you speak of occur in the past two weeks? I do not have Gmail set up in my own email program, but simply use MWP for notice that I've received something and should check it out.
Thu Oct 08, 2020 7:00 pm
GSuite is a bunch of different tools packaged up, including mail. https://gsuite.google.co.nz/intl/en_nz/
If it is a GSuite account, then the final date seems to be Feb 2021. It looks like they suspended the rollout of disabling non OAUTH access due to Covid.
https://gsuiteupdates.googleblog.com/20 ... ended.html
So this is likely not the issue.
That said, GSuite two days ago became Google Workspace, https://techcrunch.com/2020/10/06/g-sui ... workspace/
I dunno, maybe just odd timing.
Flick me some logs, could be an error coming back that tells us what's going on.
To do that go Help >> Send Support Logs >> enter a brief note like 'as per forum - genegold' >> in the Ticket Number field enter chris >> Send Logs >> reply back once sent, so I can check they arrived all OK.
genegold
Guardian Gecko
Thu Oct 08, 2020 7:08 pm
logs sent, thanks.
Thu Oct 08, 2020 7:23 pm
Great, replied to the message via email.
Lemme know how you get on.
genegold
Guardian Gecko
Thu Oct 08, 2020 8:07 pm
Anyone else having a problem with Gmail and MWP?
genegold
Guardian Gecko
Wed Oct 14, 2020 10:38 am
Google now has Community help and so I posted there. Today, five days later, and coincidentally just after posting for help again -- it hadn't been fixed as of this morning -- a gmail arrived in MWP. So I guess it's been taken care of.
Wed Oct 14, 2020 3:10 pm
Great, glad to hear it. Must be some kind of tech glitch they've been having
