latest version bug
andromeda_girl
latest version bug
Wed Dec 16, 2020 10:52 am
mailwasher pro is not saving items in 'mark as good' list. you have to set that repeatedly for the same sender now.
previous versions saved this.
Re: latest version bug
Wed Dec 16, 2020 10:58 am
Are you using any kind of cleanup software ? I've come across some examples lately of programs like AVG Tuneup deleting important MailWasher files.
andromeda_girl
Sat Feb 20, 2021 9:26 am
No such applications at all, no.
this problem first arose with the latest update [v7 i guess, which has had numerous updates since i got it] and remains.
it simply does not save what you mark as 'good', 'friends', or 'blacklist'.
also astonishingly marking blatantly obvious spam as 'good' and everything i already had marked as 'good' or 'friends' as being blacklisted.
simply refuses to save the settings it had before the update and even after i mark something as being either blacklisted/good/or friends, it still doesn't mark them properly next time the same sender pops up again.
mailwasher used to be much stronger than this, it should be a pretty basic application function.
Mon Feb 22, 2021 12:17 pm
OK, can you send me some logs.
If you go Help >> Send Support Logs >> enter a brief note like 'as per forum' >> in the Ticket Number field enter chris >> Send Logs >> reply back here once sent, so I can check they arrived all OK.
