Problem with AOL
pewe
Problem with AOL
Mon Mar 01, 2021 2:18 am
I have 2 AOL accounts.
Both are set up identically in Mailwasher (apart from username and password).
After a long time of successful access, having made no changes to the account, Mailwasher is now reporting that it is unable to login on one of the accounts - despite the account still being accessible with Thunderbird and also online using a web browser.
Anyone have any suggestions as to why this has suddenly happened.
Re: Problem with AOL
Mon Mar 01, 2021 2:27 am
If I recall, AOL have added OAUTH which MailWasher doesn't support at present, try creating an App Password to use in MailWasher
https://help.aol.com/articles/Create-an ... p-password
pewe
Mon Mar 01, 2021 3:13 am
Thank you - that did it.
Puzzling why the other AOL account still works though.
Why do they have to mess about - if it ain't broke don't fix it I say.
Thanks again.
Mon Mar 01, 2021 11:01 am
I expect they are rolling out the changes gradually across accounts, so you can probably expect the other to eventually do the same.
Gniblett
Mon Mar 15, 2021 3:49 am
MailwasherPro has just started throwing up an error and failing to connect to the AOL server, I have tried creating an in App password as you suggest but it still fails to connect. So frustrating after it has worked faultlessly till now.
Using: Windows 10 Home (64 bit) v 20H2
MailwasherPro 7.12.54
Kaspersky Internet Security 21.2.16.590(c)
Tue Mar 16, 2021 12:27 pm
Can you send me some logs. To do that go Help >> Send Support Logs >> enter a brief note like 'as per forum - AOL' >> Send Logs >> reply back once sent, so I can check they arrived all OK.
Gniblett
Wed Mar 17, 2021 3:27 am
Thank you for that offer but now not needed. Have tried again and generated another in App password and this time it worked - Hooray :cheers
I copied and pasted the generated password today, yesterday I had typed it in with no gaps. Looks like copy and paste is the way to go.
pewe
Wed Apr 28, 2021 12:20 am
Is there any plan to deal with this problem in Mailwasher in due course?
Wed Apr 28, 2021 12:30 am
We will be adding OAUTH at some point, but in the interim an App Password should work fine in MailWasher.
