MWP with AVG ?
_Chris_
MWP with AVG ?
Wed Mar 03, 2021 11:33 am
Using MW pro with AVG, keep getting slow checking on incoming emails and or errors - when switching avg off temporarily, the emails are checked dead fast with no issues. Any ideas how to solve please?
Mailwasher Pro is brilliant!
Re: MWP with AVG ?
Wed Mar 03, 2021 11:38 am
I would just switch the Email Shield scanner off in AVG. As you're using MW you are already scanning your mail and the real-time AVG scanner is the true protection.
https://support.avg.com/SupportArticleV ... tType=home
_Chris_
Re: MWP with AVG ?
Wed Mar 03, 2021 8:18 pm
Thanks, but isn't it good for AVG to check for virus's?
Re: MWP with AVG ?
Thu Mar 04, 2021 10:25 am
Ideally yes, when it works without problems.
But email scanning for viruses isn't necessary, as the main AVG engine would still work if you were to download then trigger the email virus. As you are already checking your emails MailWasher, which isn't able to activate an email virus, you've already got an extra layer of protection.
_Chris_
Re: MWP with AVG ?
Fri Mar 05, 2021 8:53 pm
Okay, thanks. Not ideal, as I really wanted AVG to work as it's meant to. On my previous exact same setup, it was a lot faster?
_Chris_
Re: MWP with AVG ?
Sat Mar 27, 2021 8:39 pm
Must admit, I'm not happy with disabling AVG. Does anyone else here also have slow downloading in Mailwasher due to AVG running?
