Version 7.11.0 custom filter
Moko
Thu Mar 04, 2021 3:28 am
Version 7.11.0
So far I have been able to set a filter with the content Sprachraum: Grossbritannien. This no longer works. Also Sprachraum*Grossbritannien remains completely without function. Only Grossbritannien, on the other hand, works. But then the filter strikes too often.
What am I doing wrong or how can I fix this?
Re: Version 7.11.0 custom filter
Thu Mar 04, 2021 10:14 am
You can't use * in Custom Filters as wild cards.
When you say the filter no longer works, it was working all OK previously ?
I would first try updating to 7.12.55 which is the latest version.
Moko
Thu Mar 04, 2021 8:13 pm
Thank you for the answer. I have run the update and there has been no change. Yes, before (I can't remember up to which version) the filter worked perfectly. I suspect the colon.
Thu Mar 04, 2021 8:21 pm
Can you email me an example and your filters file.
Under Help >> User Files >> your filters are stored in Filters.xml >> if you can email me that to [email protected] and also if you can include example text of what you want to filter for.
Moko
Thu Mar 04, 2021 8:47 pm
Suddenly it works... I created a new filter with the same content and it worked. Then I increased the priority of the original filter again and everything works as it should. There are probably ghosts on the way. Thanks a lot in any case.
Thu Mar 04, 2021 8:57 pm
Wonderful, thanks for letting me know.
