MWP 7.12.54. It's not all that unusual now and then to show a couple of saved but unsent draft msgs in my incoming mail grid that get pulled in on a mail sweep, but I'd like to add a filter so that these are sorted out etc the same as any other incoming. I currently have as the very LAST filter one that checks only for any header to contain a @ as a catch all so I can add a new one if necessary, and it works fine, but what I want is something that shows specified fields as *null*, if that's possible, not as that last one, but to catch any draft messages and sort them as any other. Is this doable?
TIA
Elaine Pack
Huntersville, NC
Checking for null value in header?
- epack
- Active Albatross
Elaine Pack
Huntersville, NC
Elaine Pack
Huntersville, NC
rusticdogru
Re: Checking for null value in header?
Sometimes it's possible, though it can vary.
If MailWasher if you choose that field to filter on, set the filter to doesn't contain, REGEX and use the full stop for any character .
That ought to trigger on a null.
You could also look at the header of these saved messages in MailWasher, I don't know about Pandora but ThunderBird adds a header line for drafts.
X-Mozilla-Draft-Info:
If Pandora does something simliar, you could filter on that instead.
- epack
- Active Albatross
Sorry, don't know what you mean by this: "use the full stop for any character" at least in this context. A dot/period? Something else?
Also, FYI Pandora is a completely new email program that was designed to have much of the look and feel of the venerable and vaunted old Eudora program, but with all the old bugs and shortcomings etc fixed and/or updated for today's email. It was not developed by Qualcomm or any other corp, it was a young man in Europe (educated in the US) who created it. He has no connection to Qualcomm or me, for that matter, other than I'm a heavy user
It's a really great program!
elaine
elaine
Elaine Pack
Huntersville, NC
Elaine Pack
Huntersville, NC
- epack
- Active Albatross
It worked!!! I set the criteria as "TO doesn't contain ." Just a simple dot, and it shows the tag I planned to give these. And of course, depending on what stage the draft was in, i.e., has a To value, there are others I can use too.
Thanks!!
elaine
Thanks!!
elaine
Elaine Pack
Huntersville, NC
Elaine Pack
Huntersville, NC
rusticdogru
No worries. I just installed Pandora as well, from a brief look Drafts get saved with the following header lines
So a more concise way to filter these could be to look if the Header, Contains, Plain Text,
X-Pandora-Index-Message-Type: 1
And if I send a message from Pandora, these lines are not included in the delivered message.X-Pandora-Message-Text-Format: 1
