Hello All:
Is there a way to put a list of emails in the blacklist. I get alot of spam e-mails sometimes numbering in the hundreds and was wondering is there a way to put them all in the blacklist or to blacklist the domain in one swell swoop as opposed to going through each email separately to list it in the blacklist, thanks for any and all responses, Allen
Putting domains in blacklist
Holding down SHIFT allows you to select all emails between the two messages you select, holding CTRL will select each message you click on,
Re: Putting domains in blacklist
With many emails selected in MailWasher you can right click and select Add Domain To Blacklist.aestone wrote: ↑Fri Mar 19, 2021 4:51 amHello All:
- aestone
