MailWasher 7.12.54 sends good emails to recycling
jehzsa
Wed May 05, 2021 9:22 am
As stated, MailWasher keeps sending "good" and "friends" emails straight to the recycling bin. Started around one month ago.
How can I fix it? No logs, it just does it.
IAT
Re: MailWasher 7.12.54 sends good emails to recycling
Fri May 14, 2021 3:29 am
These emails in the Recycle Bin, what does the evaluation on the right say ? If you cannot see that, right click on a message and select 'Show Evaluation Details'.
Also can you send me some logs.
Go Help >> Send Support Logs >> enter a brief note like 'as per forum, jehzsa' >> Send Logs >> reply back here once sent, so I can check they arrived all OK.
jehzsa
Fri May 14, 2021 8:43 am
Thank you for your reply. I forgot about this query.
I tinkered with the Spam Ratings and it has resolved the issue.
Thanks again,
