In the HTML view, the German mutated vowels are displayed incorrectly. How can I fix this?
"informieren Sie sich bitte zunächst bei der zuständigen Postfiliale, ob dort eine Sendung oder ein Paket für Sie lagert."
HTML view - german mutated vowel
- Moko
Re: HTML view - german mutated vowel
Nobody Knows the Trouble I've Seen?
https://www.youtube.com/watch?v=QNXRU05nB1Y
Can you try changing the default encoding to UTF-8 in Internet Explorer. MailWasher uses the IE engine to render HTML, so it sounds like this might be set to Western.
https://www.thewindowsclub.com/auto-sel ... t-explorer
- Moko
This seems to have worked, I will still observe whether the change has any other consequences. In any case, thank you very much.
And the next question :-)
If a mail is marked as read in the webmailer, Mailwasher no longer displays it. How can I make Mailwasher show all mails, not just the unread ones?
- ataraxy
- Knowledgeable Kea
In the Settings for the account, on the Incoming tab, open the Advanced settings and check the Download read e-mails option.
Windows 10
