Vacuums are vacuums and they do exactly what they are supposed to do - vacuuming things and give you a clean finish. However, not all vacuums work the same. There are some that will be outstanding in terms of design, price and lifespan. Today we will discuss top vacuums that are reported to have stronger suction than other models on the market. In order to determine best rated vacuums with the most suction, they undergo tests such as: dirt removal, pet hair removal, maneuverability, and loudness. Let’s dive in.
SHARK APEX Upright
This is one of the best upright bagless vacuum cleaners on the market. The Shark APEX Upright does a very good job of filtering out any tiny particles that may appear on its way. The suction power is excellent where the APEX Uprights provide a very good cleaning performance on both hard bare floors and carpets while in testing. The special feature of this model gives you the ability to convert it from an upright to a canister vacuum with the press of a button. This helps you to clean the stairs and corners more easily, as well as the places behind or under furniture. The Shark APEX Upright also comes with a washable HEPA filter which is sealed for better dust retention, making it perfect for allergy sufferers and pet owners.
Bissell Pet Hair Eraser Turbo Plus
It is no wonder that pet owners need a vacuum with decent suction power. Understanding customers’ insight, Bissell released the Pet Hair Eraser Turbo Plus with features to take care of all of the vacuum problems that pet owners have. This vacuum has capabilities that will take up and deal with even the tiniest amount of pet hair. Also, a tangle-free brush roll that keeps pet hair out of the bristles. When referring to the Best Vacuum Cleaners in the world, they all refer to the one and only important feature that the best should have-the HEPA filter. With strong suction power and a HEPA filter, plus its allergen-sealed technology traps small particles and eliminates smells, the Bissell Pet Hair Eraser Turbo Plus won the Amazon’s Choice award.
SamSung Jet 90 Complete
Usually, a cordless vacuum does not have strong suction since it operates based on battery energy, and the lower the battery, the weaker the suction. However, the Jet 90 Complete from Samsung is the best cordless vacuum cleaner on the market with the most suction when compared with other cordless models. Its impressive 3-level pick-up power and great design with a wide assortment of useful tools make it a worthwhile purchase. This best rated vacuum comes with a free-standing charging base which can be placed in any corner if you do not have storage. In fact, its appearance looks pretty aesthetic. Moreover, the Jet 90 includes a fluffy roller attachment that is specifically for wood floors to avoid scratching the surface of the wood. Finally, its dust cup and filter are super easy to empty and clean.
Conclusion
Above are the top 3 different types of vacuums with the most suction power based on Vacuum Cleaner Reviews and ratings. Each fulfills different needs and requirements of different customers. Buying a new vacuum cleaner can be a confusing task. Therefore, we hope that this article will be helpful as a reference for strong suction vacuum cleaners.
