Thunderbird mail client not opening after mailwashing
- davalew
I've had MailWasher since day one and have always enabled the program to open my mail client after mailwashing but recently, although the option is selected in Wash Mail Settings, the client does not open and has be be specifically opened every time. Any suggestion to the cause and what I can do to rectify the fault?
As a quick test, try sending yourself an email, load it into MailWasher >> Wash Mail with the new email still there, see if ThunderBird opens.
Re: Thunderbird mail client not opening after mailwashing
Do you have any new emails to retrieve ? If there are no new messages MailWasher won't trigger ThunderBird automatically, so that could be why it's not opening.davalew wrote: ↑Tue Jul 20, 2021 10:07 pmI've had MailWasher since day one and have always enabled the program to open my mail client after mailwashing but recently, although the option is selected in Wash Mail Settings, the client does not open and has be be specifically opened every time. Any suggestion to the cause and what I can do to rectify the fault?
- davalew
The fault is that having washed away the spam, the remaining messages which are genuine should show up in the Thunderbird email client which for years has automatically opened at that point in the cycle but now no longer does. Mailwasher has always opened Thunderbird when there is washed mail and the settings say that it should but it doesn't.
OK great. Can you send me some logs. First be sure you've washed mail on the current day expecting ThunderBird to open, then in MailWasher go Help >> Send Support Logs >> enter a brief note like 'as per forum' >> in the Ticket Number field enter chris >> Send Logs >> reply back here once sent, so I can check the logs arrived all OK.
- davalew
Thanks.
The logs show MailWasher sending the command twice today to open ThunderBird after the Wash Mail is completed.
So it seems like that part of MailWasher is going OK.
If you hit the ThunderBird button in MailWasher, does it open the program at all ?
What you could try, is go Settings >> General >> Washing Mail >> in the drop down select any other option >> Save >> then select ThunderBird again >> Save.
Code: Select all
07-21-2021 10:11:03.238 MWPUI Launching mail program after wash
07-21-2021 10:11:03.238 MWPUI Minimising UI
07-21-2021 10:11:03.239 MWPUI launching path = "C:\Program Files (x86)\Mozilla Thunderbird\thunderbird.exe" with arguments: -mail
- davalew
No, the button responds but there is no resultant action.
- davalew
Selected another option and saved it and then re-entered Thunderbird and saved that but there is no difference.
OK sure thing.
If you have a desktop shortcut to open ThunderBird go Settings >> General >> Washing Mail >> select Use Other Application >> then click the Browse button and navigate to your desktop (should have a shortcut on the left) and then select the ThunderBird option that appears >> click Open >> Save.
If you don't have a desktop shortcut go Settings >> General >> Washing Mail >> select Use Other Application >> then click the Browse button and navigate to "C:\Program Files (x86)\Mozilla Thunderbird\" and there should be a thunderbird.exe that appears >> select that and click Open >> Save.
Try either of those, let me know how it goes.
- davalew
That solved it! Thanks for the work-around. I'm not sure what changed on the original settings but linking direct to the program exe file seems to work perfectly. Thanks
