MW No Longer Opens On Top
maspick
Thu Aug 12, 2021 12:05 pm
After a reboot today of Win10 machine, my MW 7.12.54 no longer opens on top of opened windows. Is there a setting that I'm missing? I've been using MW for over 15 years and this change is highly annoying. ANyone have any suggestions?
Re: MW No Longer Opens On Top
Thu Aug 12, 2021 12:12 pm
So this is on startup of the machine, MailWasher isn't taking focus ?
Check under Settings >> General >> Application >> that MailWasher is not set to start minimised, if it is uncheck >> Save.
maspick
Fri Aug 13, 2021 5:28 am
I've changed that setting as you suggest, but my problem is with launching the program from the icon in the tray - it opens but as a background window instead of becoming the window with focus. Again, this began right after the latest update to Win10.
Fri Aug 13, 2021 11:32 am
Do any other programs do this, or just MailWasher ?
I would start by running a system file check on the machine, to repair any damaged or corrupt system files. First running the DISM command, then the SFC, details are here
https://support.microsoft.com/en-us/top ... 6e85d4094e
maspick
Sat Aug 14, 2021 5:55 am
This is only happening with MW. I ran the 2 scans and they found nothing wrong.
maspick
Sun Aug 15, 2021 9:13 am
Update: it has started happening with Explorer windows, so this is a Windows thing, not MW.
Tue Aug 17, 2021 1:18 am
OK sure thing.
First, try a right-click on the taskbar and uncheck Lock the taskbar. Once unlocked, right click again and select lock.
If still no good, then from the Search icon type Control Panel >> open this then open the Ease of Access Center >> click the item 'Make the mouse easier to use' >> make sure option 'Activate a window by hovering over it with the mouse' is not checked.
Also try checking 'Prevent windows from being automatically arranged when moved to the edge of the screen'
If that doesn't work, then from Search type REGEDIT and open the Registry Editor >> on the left navigate to HKEY_CURRENT_USER\Control Panel\Desktop then with Desktop selected on the left, on the right look at the two values, ForegroundFlashCount and ForegroundLockTimeout. What are these showing for you ?
