Just sent support logs for unknown error.
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>f522bc638fb02c88183d3351d4657194</ID><DT>2021-09-16 21:14:04</DT><MWPEXCEPTION><UID>Exception 9e8d81aabfefca78d5c2270160305c60</UID><AID>Acct-134011994</AID><SOURCE>MWPfetch::FetchThread()</SOURCE><MESSAGE>Unknown error</MESSAGE><ADDXML></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
Thanks in advance for a solution.
Phil
unknown error strikes again
Re: unknown error strikes again
Quick fix ought to be, remove the Robert Robo account >> restart MailWasher >> Add it back.
I can't see when the problem started, as it must have begun the day prior, but MW was hung up on a message, then when you restarted it still was failing out with a message I don't recall seeing.
09-16-2021 21:14:04.485 Info EMPTY MESSAGE
If that isn't the most useless logging to put, I don't know what is.
Let me know if that doesn't get you up and running again. My worry would be that there is something about this specific email MW doesn't like, but I'm hoping it was just some bad data.
- philsbbs
- Active Albatross
Issued resolved by its self maybe stuck email that they deleted by chance.
