Upgrade From Free Version of MailWasher to MailWasher Pro 7
- SherlockCD
I recently upgraded my version of MailWasher from the free version to MailWasher Pro 7. Does this upgrade require me to download a different file than the one I downloaded to set up the free version of MailWasher? Please advise. Thanks!
Re: Upgrade From Free Version of MailWasher to MailWasher Pro 7
No it should run just fine.
If you do run into any troubles, uninstall MailWasher, answer YES to keep your data files so nothing is lost, then install MailWasher Pro.
