Move mailwasher pro license to a new pc
wtpeters
Fri Oct 22, 2021 10:37 am
I want to move a permanent license from an old PC to a new PC.
Can this be done?
Bill Peters
Re: Move mailwasher pro license to a new pc
Fri Oct 22, 2021 10:46 am
Hi Bill
To do manually, go into Help >> Common Files >> copy the file named key.file >> move that to new machine in same location >> restart MailWasher.
The manual location of the file is C:\ProgramData\Firetrust\MailWasher if on a default installation.
Optionally, just re-enter the license on the new machine. I had a quick look at your license and it was at the activation limit, so I've reset that. If you were getting errors, that will fix those.
