I am trying out MW Free 7.12.57 and MW mobile on Android.
Suddenly, even after adding some senders to the "Friends" list, they have been removed from the server! When I look at the recycle bin, I see them there but when I try to restore them, they don't restore.
Also, in the desktop version, not all e-mails were showing.
What am I doing wrong?!?!
Larry
only some emails showing from Yahoo
Re: only some emails showing from Yahoo
Hi Larry
For the restore
The a Yahoo account go Settings >> Accounts >> Outgoing >> check the SMTP server is smtp.mail.yahoo.com
SMTP Authentication should be checked and set to use Same As Incoming
Secure Connection should be SSL
A Zoho account also the above, but the SMTP server address should be smtp.zoho.com.au
Let me know if that doesn't help
For the restore
I forgot to reply about only some emails showing.
Under Settings >> Accounts >> Incoming >> I assume MailWasher is set to use IMAP ? Assuming so, MailWasher only loads Unread Emails from the last 7 days. You can change that behaviour by clicking Advanced in the incoming settings, there are the two options 'Download Read Email' and the drop down to choose how many days of messages to load.
- larryjb
Thanks, I will check the outgoing SMTP.
I have now changed the "download read email" so that all e-mails download.
All checked, seems to be working fine. Thanks.
