Syncing my Laptop MW Pro Installation with my Desktop PC Installation ???
shazinoz2
Fri Dec 24, 2021 2:18 am
Hi All
I'm having an issue with Outlook on my desktop PC so am having to use my laptop instead. Unfortunately, my email is currently POP3 so not able to sync them :-( so I've installed my Lifetime subscription MW Pro on my laptop in the hope it would be a single user account & therefore would show all logged emails for restoring when I transition back to my desktop PC.
It's installed fine on my laptop but on here, the recycle bin is only displaying the few emails that have come through since, not all my historical ones that are there (& are visible on my desktop MW Pro)
Does anyone know how I can have the 2 MW Pros synced to show ALL mail on BOTH ?
Also, I've duplicated my MW Pro desktop configurations/display settings screen by screen but on my laptop, the display colours aren't reflecting ?
Re: Syncing my Laptop MW Pro Installation with my Desktop PC Installation ???
Fri Dec 24, 2021 7:03 pm
The files you want are under Help >> User Files.
You could also go File >> Export >> set to include Learning >> give the file a name and save location. This creates a xxxxx.MWP file that you could then copy across to the laptop and run that file, MailWasher will import everything from the other machine.
