Key has been registered too many times
Conard.d
Tue Mar 22, 2022 8:29 am
I have found this problem posted before but no openly listed fix.
I bought a replacement laptop and when setting it up I ran across the subject problem.
Is there an easy way to get this fixed?
Re: Key has been registered too many times
Tue Mar 22, 2022 10:58 am
Hi there
Just let us know when you see this and we can reset the license for you.
I've done that now, will be good to go
Conard.d
Tue Mar 22, 2022 12:25 pm
Thank You, all is well.
